i need help plz
2 replies · 1,854 views · Started 15 April 2004
how can i upload the skins to the motorola A925 when i upload them the it says there is no viwer for this file
mmg4ever wrote:how can i upload the skins to the motorola A925 when i upload them the it says there is no viwer for this file
Make sure that you're using:
a) JPG
b) Make sure that JPG file is Internet Compatable (for some reason some aren't)
c) make sure that the file isn't too big (although I doubt that this is the case)
To change the skins on an A920/A925 you first have to load the phone skins on to your phone (Not memory card)
You can find the Toothpaste & Lunchbox skins on the CD
There are also 2 others that can be found at http://www.three4less.com/skins/ called Metallic & Clouds photo skin
Conect your phone to your computer using desktop suite and click on the My A920 (or A925 depending on what phone you have)
then click on these folders
C: / documents / Media Files / other / phone skins
Copy the phone skins into the folder.
To change between the different phone skins
click on the phone icon
click on Settings
click on Display
This will bring up a popup box and you will be able to change your phone skin
