Extended Profiles Idea !
9 replies · 2,373 views · Started 16 September 2002
dont know if this has been mentioned or even implemented since i last looked but whilst im thinking about it thought i would post about my idea !
What if it automatically switched to Silent mode when you have appointments / meetings in your calendar for a certain duration !
simple or what ! ... Now for some one to tell me its already been done ! :0)
Thanks !
Note to Programmers ! - do i get a free copy if implememted into your next update 😉 PLEASE ... 😊
Now for someone to tell me they thought of it first ... hehhehehhe
umm yes this idea has been done sorry
its called 'Extended Profiles' and its by Psilock if I recall
it pretty much does what you suggested
you can set times and assign profiles which it will autmatically switch too.
ooooops sorry sorry lol
im sitting here thinking, hes called the thread, the exact name of the program he must know about it.
so I read your opening post 3 times andf inally saw you mean synchronisation with your calander and the app
sorry mate, and yes very good idea.
The PSiLock app only seems to switch at specified times ... which seems pretty dumb to me since it assumes that you are always doing the same things. I decided not to buy it.
OTOH, the suggestion to have a smart switching capability based on your calendar is a good start at getting to a 'context' aware application capability - although I would want it to confirm the change with an alarm or something (otherwise you might assume it was still set to ring and it was now set to silent). Indeed, thinking about it, you would need the capability to override the new setting and some extensions in the calendar applications ... which sort of implies extensions to Outlook to handle it.
Although more difficult to do, it would be much more interesting and useful - enhancing the user experience rather than implementing what a programmer found easy to do.
eeeeeh not just a pretty face huh !
my problem is that when i type on screen what is in me hed it never actually comes out as i want it to sound so thats why a few of you may have had a tad of trouble understanding my concept !
one good thing tho ! it aint been done yet 😊 If this gets done then i will buy it but other than that to me it is good but only half the software that i need !
I will get on my soapbox here tho ... do any other ppl think that some of the programs that have been released should have been made by nokia and already on the phone ! ( i.e. SeleQ feature to lock Keypad on close ... I bouhgt it for that at first but then got more from it ) 8)
Just got mailled back !
Dear Sir,
Sorry for late reply.
Nice idea. After some researching was written to Extended Profiles ToDo list.
Will be implemented in next release of eProfiles.
Best regards,
PSILoc support team
PsiNT (PSILoc)
Poland
Phone: +48-94-3477766
Nokia 92xx/7650 software: http://psiloc.com
Psion software: http://psion.psiloc.com
Email: mailto:[email protected]
So I DONT get a free copy then ? DOH ! Seems they liked my idea though and this obviously seems good around these communities as the companies ( exept Nokia that is ) listen to consumers ideas...
Gr8 Stuff
Beleive me, Nokia is listening ... just not saying anything.
I thought my extension would have been worth a copy too - lol :cry:
