need help on install theme into my 6600? and why all the call time is mess up /?
2 replies · 3,717 views · Started 15 April 2004
can someone help me with this problem after i download the theme and how can i send it to my phone and how to install it??
2nd problem i have, is the call log is always mess up , and all the call include missed call ,dialed call, receieve call are way off than the actual call time i had?
Theme installation:
1: Download it to a PC and send it to the phone using infrared (IrDA). Requires an infrared port/adapter on the PC.
2: Download it to a PC and send it to the phone using Bluetooth. Requires a Bluetooth adapter on the PC.
3: Use Nokia PC Suite (requires infrared or Bluetooth) feature to install applications to the phone.
4: Use a PC based MMC card reader and copy it to the MMC and then put the MMC in the phone.
5: Send it as an email attachment to an email account which you have set up to be used directly from the phone.
6: Use the phone's browser ("Services"😉 to go to a web or WAP site from where you can download/install it.
For specifics, see the User's Guide, PC Suite on-line documentation, your Bluetooth adapter documentation and/or use the search feature on this site to find existing discussions/instructions: http://www.allaboutsymbian.com/forum/search.php
If you have pc suite and Bt you can just double click the .sis file on the pc and it will send and install in one go without even opening up pc suite. 😊
