Sending .sis file from one 6600 to another
3 replies · 2,215 views · Started 15 April 2004
What it is i've d/l a few games and apps to my phone which are situated in the inbox folder of my phone, but I would like to send some of the files over to a friend who also has a bluetooth phone. Is this possible. Also if i've uninstalled a file from apps manager but i've still got the d/l file in my inbox can I then install from there? as i've tried but to no avail !
If your *.sis is located in the inbox of the device you should be able to install just by opening the file.
If you wanted to send it to another phone you would need to locate the *.sis file using a 3rd party file manager. Look in C:/system/mail. Once you have located the file, select Send via Bluetooth.
I use Fileman by Symbianware. This has a link directly to the Mail directory.
Forward works with sis files that are stored on the mmc also,ive got it working but you need the new forward file
