Access denied!!! . . . what the . . . help!
2 replies · 1,902 views · Started 16 April 2004
First let me say this:
The P900 is THE best smartphone, its versatility is awesome and the handwriting recognition is very good. I upgraded from a Nokia 3650, which I have to say was also very good, but I've no regrets the P900 is simply much better.
However . . .
I do have some issues, my main problem is this:
How do I uninstall the unistallable files? For example I have both 'SMan' and 'Philips Camcoder' both of which will not uninstall saying 'Access denied', whats all that about!? Any help would be much appreciated.
Also, is there any way of sending more then one picture at a time via bluetooth to a computer, or do you have to view each one in turn and send them individually?
Many thanks!
For the uninstall issue i have no idea but is the programs still running eg Sman still running in the background when you want to uninstall it, if so try to close it first ...
as for the picture sending issue, go to the File Manager go to the picture folder where you keep your images. Tick all the pictures you want to send and choose File - Send As - Bluetooth (at the upper part of the screen)
