Time Synch Problem between P900 and Outlook 2003
3 replies · 3,972 views · Started 16 April 2004
So has anybody else come across this 'feature'....
Since 'Daylight Savings' came in at the end of March, I have been unable to get calendar items synching correctly between Outlook 2003 (set with DST on) and my P900. I am using v2.3.1 of the synch software and have disabled time synch between the PC and P900.
I have variously fiddled with the 'Summertime' option on P900 but consistently my calendar times on the P900 are 1 hour ahead of the real time I set for the item on the PC.
Does anybody know what time info actually gets synched across - I would have thought it was the time in UTC form so don't understand why it is always appearing incorrectly.
I am getting really frustrated!! Please help!!
Hi, I had the same problem. My time settings was Norway, Oslo and other country was set to United Kingdom and London. When I set both to Norway Oslo it worked.
...or, a much better synch suite! this isnt good. the suite for my siemens sl55 was far better. come on SE, try harder 😞
