ETI Camcorder for 6600
17 replies · 11,732 views · Started 17 April 2004
I've downloaded the ETI camcoder software. It's pretty nice and without time limitation. The only problem is it produce file format which isn't recognized by any standard PC video software players. That's a bit pitty cause it limits me to view the movies only on my phone.
Does anyone has another solution?
If you got the program legitimatley you would have received a converter to convert the files to .avi's
Will
Lior wrote:I've downloaded the ETI camcoder software. It's pretty nice and without time limitation. The only problem is it produce file format which isn't recognized by any standard PC video software players. That's a bit pitty cause it limits me to view the movies only on my phone.
can you tell where you got the program? is it a trial version or did you buy the full version? may you tell me the web address? thanks...
boga turkey wrote:can you tell where you got the program? is it a trial version or did you buy the full version? may you tell me the web address? thanks...
hello there,
plz tell me from which site did u download this etic camcorder ,my email is [email]removed[/email] plz do tell me
hi, i've download ETI cam corder pro, i can install it but i can't record the video...
who can help me?
i have do the software upgrade yesterday...
turn the audio off in the settings if u cant play etic camcorder on ur phone, also i think they are standard 3gp files rnt they? which nokia multimedia player can play or quicktime
GhostDog wrote:Nope.
I have not followup 3rd party camcoder for a few months, sad to say that people still using ETI which does not fully compatiable with 6600.
Me too, still using ETI, recording video without audio, sigh ~~~ :frown:
Can sonebody tell me what is the name of converter that convert eti files *.eye and *.ear ( *.ear can be renamed in to *.amr and pleyed in nokia multimedia pleyer ) or where can I find it on the wab :icon4:
kia0047 wrote:I have not followup 3rd party camcoder for a few months, sad to say that people still using ETI which does not fully compatiable with 6600.
ETI Camcoder is fully compatible with the latest 6600 firmware version.
EYECON and ETI Camcorder are one package.
or look for Aniviewer on the same sites i told in the previous post. Guess you will find one of them.
Yep the ETI cam corder is fully compatible with nokia 6600 provided that your firmware is 4.06 something i think, althought the quality in ETI is not as clear as real player video which is 10 seconds only..
Soryy, I dont have any solution about that but if you please send me this program. I have Nokia 6600 mobile but ı can not find the program , please help me about that with sending the program 😊)).
Thanking in advance,
Osman �zdemir
[email][/email]
