Correct Vodafone UK Data Settings
2 replies · 1,960 views · Started 17 April 2004
I got the settings (GPRS & GSM) from vodafone's web site, and I cannot get access to Traffic-I server or Worldmate server, but if I use the Mviva data settings (GSM) then I can access it.
So could someone with both these programs tell me the correct settings?
N
You need Vodafone Internet GPRS not WAP GPRS.
The settings have been posted many many times you should do a search.
But of the top of my head I think you need to duplicate the WAP GPRS settings but where it has the gateway IP address you should change it to 0.0.0.0 and you should find internet now works.
Will
Create a GPRS connection with the following settings.
APN = internet
username = web
password = web
This will give you access to WEB GPRS not WAP GPRS, the settings which you have sent via the internet are for WAP broswing not WEB broswing.
