Is there a way to refresh / format the p900.
And have a compleatly new fresh system.
I know there is an option in control panel , but the problem is i dont remember the code.
When i purchased the phone the code of already in there. ( Is there a way to find or remove the code/ pin )
Format / reload p900
isn't the pincode sim-related? so if you remove the simcard and put in another without a pincode it should work
0000
if you dont know the password try 0000, it is the default password
else I think you can follow these steps.
1 . Full Backup your system
2 . Goto Sony Update site, update your phone (http://www.sonyericsson.com/updateservice/P900)
3 . It will format entire system, and will update its firmware to a new version
I updated my system 2 or 3 days ago, and it did not ask me system password, so i think you can update yours
good luck 😊
