missing NOKIA7650IRDA.INF file for modem setup with XP
4 replies · 4,630 views · Started 17 September 2002
i wanted to use my 7650 via infrared as a modem but everything is ok untill i am asked to upgrade the windows xp driver by the "nokia7650irda.inf" driver and guess what it does not exist!!!
If you download ....
http://nds1.nokia.com/phones/files/software/N7650_Modem_Setup.exe
And then unzip the .exe, and open up the cabs inside, you'll find NOKIA7650IRDA.INF, which contains ...
[Version]
LayoutFile=layout.inf
Signature="$WINDOWS NT$"
Class=Modem
ClassGUID={4D36E96D-E325-11CE-BFC1-08002BE10318}
Provider=%Nokia%
[ControlFlags]
ExcludeFromSelect = *
[DestinationDirs]
; Specify destination directories for groups of files.
; '12' indicates the Windows System32\drivers directory.
MSIRCOMM.CopyFiles=12
DefaultDestDir=12
[Manufacturer]
%Nokia% = Nokia
[Nokia]
%Nokia1%=Nokia1,IRENUM\NMP765A ; 7650
[Nokia1.NT]
AddReg=All, External, Nokia.Addreg, Nokia1.Addreg, Nokia.Responses
CopyFiles=MSIRCOMM.CopyFiles
[Nokia1.NT.Services]
AddService= MSIRCOMM, 0, MSIRCOMM.AddService
[Nokia1.NT.HW]
AddReg=LowerFilterAddReg
; called by needs entry in oem inf - DON'T REMOVE
[MDMIRMDM.MSIRCOMM.CopyFiles]
[MDMIRMDM.MSIRCOMM.AddService]
[MDMIRMDM.MSIRCOMM.LowerFilterAddReg]
[MSIRCOMM.CopyFiles]
;MSIRCOMM.sys
[MSIRCOMM.AddService]
DisplayName = %MSIRCOMM.DisplayName%
ServiceType = 1 ;%SERVICE_KERNEL_DRIVER%
StartType = 3 ;%SERVICE_DEMAND_START%
ErrorControl = 1 ;%SERVICE_ERROR_NORMAL%
ServiceBinary = %12%\MSIRCOMM.sys
[LowerFilterAddReg]
HKR,,"LowerFilters",0x00010000,MSIRCOMM
[All]
HKR,,ConfigDialog,,modemui.dll
HKR,,PortSubClass,1,02
HKR,,EnumPropPages,,"modemui.dll,EnumPropPages"
; DeviceTypes
[EXTERNAL]
HKR,, DeviceType, 1, 01
[SERIAL]
HKR,, DeviceType, 1, 00
[Nokia.Addreg]
HKR,, Reset,, "ATZ<cr>"
HKR,, ConfigDelay, 1, 88, 13, 00, 00
HKR, Init, 1,, "AT<cr>"
HKR, Init, 2,, "AT&FV1E0&D2&S0&C1S0=0+CVHU=1<cr>"
HKR, Monitor, 1,, "ATS0=0<cr>"
HKR, Monitor, 2,, "None"
HKR, Hangup, 1,, "ATH<cr>"
HKR, Answer, 1,, "ATA<cr>"
HKR, Settings, Prefix,, "AT"
HKR, Settings, Terminator,, "<cr>"
HKR, Settings, DialPrefix,, "D"
HKR, Settings, DialSuffix,, ""
HKR, Settings, CallSetupFailTimer,, "S7=<#>"
HKR, Settings, FlowControl_Off,, "&K0"
HKR, Settings, FlowControl_Hard,, "&K3"
HKR, Settings, FlowControl_Soft,, "&K4"
;HKR, Settings, Compression_Off,, "+DS=0,0;"
;HKR, Settings, Compression_On,, "+DS=3,0;"
HKR, Fax\Class2\AdaptiveAnswer\AnswerCommand, 1,, "ATS7=90S25=2"
HKR, Fax\Class2\AdaptiveAnswer\AnswerCommand, 2,, "ATA"
HKR, Fax\Class2\AdaptiveAnswer, ModemResponseFaxConnect,, "+FCO"
HKR, Fax\Class2\AdaptiveAnswer, ModemResponseDataDetect,, "CARRIER"
HKR, Fax\Class2\AdaptiveAnswer, ModemResponseDataConnect,, "CONNECT"
[Nokia1.Addreg] ;6310
HKR,, Properties, 1, 00,00,00,00, FF,00,00,00, 00,00,00,00, 00,00,00,00, 00,00,00,00, 31,00,00,00, 00,C2,01,00, 00,E1,00,00
[Nokia.Responses]
; OK
HKR, Responses, "<cr><lf>OK<cr><lf>", 1, 00, 00, 00,00,00,00, 00,00,00,00
HKR, Responses, "0<cr>", 1, 00, 00, 00,00,00,00, 00,00,00,00
; Negotiation Progress
HKR, Responses, "<cr><lf>CARRIER<cr><lf>", 1, 01, 00, 00,00,00,00, 00,00,00,00
HKR, Responses, "16<cr>", 1, 01, 00, 00,00,00,00, 00,00,00,00
HKR, Responses, "<cr><lf>SMS<cr><lf>", 1, 01, 00, 00,00,00,00, 00,00,00,00
HKR, Responses, "17<cr>", 1, 01, 00, 00,00,00,00, 00,00,00,00
; Connect
HKR, Responses, "<cr><lf>CONNECT<cr><lf>", 1, 02, 00, 00,00,00,00, 00,00,00,00
HKR, Responses, "1<cr>", 1, 02, 00, 00,00,00,00, 00,00,00,00
HKR, Responses, "<cr><lf>CONNECT 300<cr><lf>", 1, 02, 00, 2c,01,00,00, 00,00,00,00
HKR, Responses, "<cr><lf>CONNECT 1200<cr><lf>", 1, 02, 00, b0,04,00,00, 00,00,00,00
HKR, Responses, "5<cr>", 1, 02, 00, b0,04,00,00, 00,00,00,00
HKR, Responses, "<cr><lf>CONNECT 2400<cr><lf>", 1, 02, 00, 60,09,00,00, 00,00,00,00
HKR, Responses, "10<cr>", 1, 02, 00, 60,09,00,00, 00,00,00,00
HKR, Responses, "<cr><lf>CONNECT 4800<cr><lf>", 1, 02, 00, C0,12,00,00, 00,00,00,00
HKR, Responses, "11<cr>", 1, 02, 00, c0,12,00,00, 00,00,00,00
HKR, Responses, "<cr><lf>CONNECT 9600<cr><lf>", 1, 02, 00, 80,25,00,00, 00,00,00,00
HKR, Responses, "12<cr>", 1, 02, 00, 80,25,00,00, 00,00,00,00
HKR, Responses, "<cr><lf>CONNECT 14400<cr><lf>", 1, 02, 00, 40,38,00,00, 00,00,00,00
HKR, Responses, "17<cr>", 1, 02, 00, 40,38,00,00, 00,00,00,00
HKR, Responses, "<cr><lf>CONNECT 19200<cr><lf>", 1, 02, 00, 00,4B,00,00, 00,00,00,00
HKR, Responses, "18<cr>", 1, 02, 00, 00,4B,00,00, 00,00,00,00
HKR, Responses, "<cr><lf>CONNECT 28800<cr><lf>", 1, 02, 00, 80,70,00,00, 00,00,00,00
HKR, Responses, "19<cr>", 1, 02, 00, 80,70,00,00, 00,00,00,00
HKR, Responses, "<cr><lf>CONNECT 38400<cr><lf>", 1, 02, 00, 00,96,00,00, 00,00,00,00
HKR, Responses, "20<cr>", 1, 02, 00, 00,96,00,00, 00,00,00,00
HKR, Responses, "<cr><lf>CONNECT 48000<cr><lf>", 1, 02,00, 80,BB,00,00, 00,00,00,00
HKR, Responses, "21<cr>", 1, 02,00, 80,BB,00,00, 00,00,00,00
HKR, Responses, "<cr><lf>CONNECT 56000<cr><lf>", 1, 02,00, C0,DA,00,00, 00,00,00,00
HKR, Responses, "22<cr>", 1, 02,00, C0,DA,00,00, 00,00,00,00
; Error
HKR, Responses, "<cr><lf>ERROR<cr><lf>", 1, 03, 00, 00,00,00,00, 00,00,00,00
HKR, Responses, "4<cr>", 1, 03, 00, 00,00,00,00, 00,00,00,00
HKR, Responses, "<cr><lf>+FCERROR<cr><lf>", 1, 03, 00, 00,00,00,00, 00,00,00,00
HKR, Responses, "+F4<cr>", 1, 03, 00, 00,00,00,00, 00,00,00,00
; No Carrier
HKR, Responses, "<cr><lf>NO CARRIER<cr><lf>", 1, 04, 00, 00,00,00,00, 00,00,00,00
HKR, Responses, "3<cr>", 1, 04, 00, 00,00,00,00, 00,00,00,00
;No Dial Tone
HKR, Responses, "<cr><lf>NO DIALTONE<cr><lf>", 1, 05, 00, 00,00,00,00, 00,00,00,00
HKR, Responses, "13<cr>", 1, 05, 00, 00,00,00,00, 00,00,00,00
HKR, Responses, "<cr><lf>BLACKLISTED<cr><lf>", 1, 1C, 00, 00,00,00,00, 00,00,00,00
HKR, Responses, "14<cr>", 1, 1C, 00, 00,00,00,00, 00,00,00,00
; Busy
HKR, Responses, "<cr><lf>BUSY<cr><lf>", 1, 06, 00, 00,00,00,00, 00,00,00,00
HKR, Responses, "7<cr>", 1, 06, 00, 00,00,00,00, 00,00,00,00
; No Answer
HKR, Responses, "<cr><lf>NO ANSWER<cr><lf>", 1, 07, 00, 00,00,00,00, 00,00,00,00
HKR, Responses, "8<cr>", 1, 07, 00, 00,00,00,00, 00,00,00,00
; Ring
HKR, Responses, "<cr><lf>RING<cr><lf>", 1, 08, 00, 00,00,00,00, 00,00,00,00
HKR, Responses, "2<cr>", 1, 08, 00, 00,00,00,00, 00,00,00,00
; Compression
HKR, Responses, "<cr><lf>+DR: NONE<cr><lf>", 1, 01, 00, 00,00,00,00, 00,00,00,00
HKR, Responses, "<cr><lf>+DR: V42B<cr><lf>", 1, 01, 01, 00,00,00,00, 00,00,00,00
HKR, Responses, "<cr><lf>+DR: V42B RD<cr><lf>", 1, 01, 01, 00,00,00,00, 00,00,00,00
HKR, Responses, "<cr><lf>+DR: V42B TD<cr><lf>", 1, 01, 01, 00,00,00,00, 00,00,00,00
HKR, Responses, "<cr><lf>+DR: MNP5<cr><lf>", 1, 01, 01, 00,00,00,00, 00,00,00,00
; Service Reporting Control
HKR, Responses, "<cr><lf>+CR: ASYNC<cr><lf>", 1, 01, 00, 00,00,00,00, 00,00,00,00
HKR, Responses, "<cr><lf>+CR: REL ASYNC<cr><lf>", 1, 01, 00, 00,00,00,00, 00,00,00,00
; Error Control Reporting
HKR, Responses, "<cr><lf>+ER: NONE<cr><lf>", 1, 01, 00, 00,00,00,00, 00,00,00,00
HKR, Responses, "<cr><lf>+ER: LAMP<cr><lf>", 1, 01, 00, 00,00,00,00, 00,00,00,00
HKR, Responses, "<cr><lf>+ER: ALT<cr><lf>", 1, 01, 00, 00,00,00,00, 00,00,00,00
; Distinctive Ring
HKR, Responses, "<cr><lf>+CRING: ASYNC<cr><lf>", 1, 08, 00, 00,00,00,00, 00,00,00,00
HKR, Responses, "<cr><lf>+CRING: REL ASYNC<cr><lf>", 1, 08, 00, 00,00,00,00, 00,00,00,00
HKR, Responses, "<cr><lf>+CRING: FAX<cr><lf>", 1, 08, 00, 00,00,00,00, 00,00,00,00
HKR, Responses, "<cr><lf>+CRING: VOICE<cr><lf>", 1, 08, 00, 00,00,00,00, 00,00,00,00
HKR, Responses, "<cr><lf>+CRING: VOICE/ASYNC<cr><lf>", 1, 08, 00, 00,00,00,00, 00,00,00,00
HKR, Responses, "<cr><lf>+CRING: VOICE/REL ASYNC<cr><lf>", 1, 08, 00, 00,00,00,00, 00,00,00,00
HKR, Responses, "<cr><lf>+CRING: ALT VOICE/ASYNC<cr><lf>", 1, 08, 00, 00,00,00,00, 00,00,00,00
HKR, Responses, "<cr><lf>+CRING: ALT VOICE/REL ASYNC<cr><lf>", 1, 08, 00, 00,00,00,00, 00,00,00,00
HKR, Responses, "<cr><lf>+CRING: ALT ASYNC/VOICE<cr><lf>", 1, 08, 00, 00,00,00,00, 00,00,00,00
HKR, Responses, "<cr><lf>+CRING: ALT REL ASYNC/VOICE<cr><lf>", 1, 08, 00, 00,00,00,00, 00,00,00,00
HKR, Responses, "<cr><lf>+CRING: ALT VOICE/FAX<cr><lf>", 1, 08, 00, 00,00,00,00, 00,00,00,00
HKR, Responses, "<cr><lf>+CRING: ALT FAX/VOICE<cr><lf>", 1, 08, 00, 00,00,00,00, 00,00,00,00
[Strings]
MSIRCOMM.DisplayName= "Microsoft IR Communications Driver"
Nokia = "Nokia"
Nokia1 = "Nokia 7650 (IrDA)"
