original nokia tones
3 replies · 8,538 views · Started 20 April 2004
You can't easily loose them, as they're in the read-only memory (ROM), under the Z:\Nokia\Sounds directory/folder (if you look at them with a file manager like FExplorer, which you can get from http://www.gosymbian.com/).
if you really lost it... try borrowing phone from your friends or if u have an extra phone at home install it wit seleQ then send the original nokia tones to your phone!:rock: :creep:
