Viewing PDFs
7 replies · 2,551 views · Started 20 April 2004
Can I use the P900 to view pdf files downloaded to the device from the internet without the use of a pc ?
I wan't to get some type of pda/phone device and I need to be able to view pdfs with it.
Matt
Or from what the sonyericsson site says, have not tested it.
You can download the viewer filters and do it that way.
Have tested it with ms office files and works 100%
KayonLord wrote:Or from what the sonyericsson site says, have not tested it.
Do you have a link I can't find the info you are referring to ?
Another SW is good one for reading the PDF. word and etc.
Maybe you can try repligo. It is also good SW
