Dear All,
I have Nokia 6600. Do I have to wait until the device tells me that "battery is low" or I can charge it any time on any level?
Thank you for your reply in advance.
Dear All,
Dear U,
U can charge ur battery depends on ur battery level bar(on the screen).When the battery level bar is half, charge it. Full battery level bar can stands about 11/2 day.
Device will tell when battery is full load. Usually color screen mobile eats more battery power. Ppl says off ur mobile when u want to charge it just for more power. Ppl says, not me... 🙄
[FONT=Century Gothic]>>Accumalator mobile phone on stores now!!! [/FONT]
does any one know tmobiles gprs settings 🙄 🙄 🙄 😃
flaco013 wrote:does any one know tmobiles gprs settings 🙄 🙄 🙄 😃
For the 6600 (that's the forum you're using - you don't actually say what phone you have) they're as follows
Step
Action
1
Press the [Menu] key located on the edge of the handset, to the left of the 1 key
2
Scroll to [Services] and press down on the [Central Toggle Key]
3
Press the [Options] button
4
Scroll to [Settings] and then press [Select]
5
With [Default Access Point] highlighted press down on the [Central Toggle Key]
6
If this is the first set of setting that have been done the following message will appear: "No access points defined. Define Now?"
Does this message appear?
If Yes, Press the [Yes] key and go to step 8
If no, go to next step.
7
Highlight [t-zones GPRS] and press [Options]
Scroll to [Edit] and press the [Select] button, then go to step 9
8
Press Options
Scroll to [New access point] and press the [Select] button
With [Use default settings] selected press the [Select] button
9
With [Connection name] highlighted press down on the [Central Toggle Key]
10
Rename [Connection] to [t-zones GPRS] then click [Ok]
Note: Use the * button for symbols and the 0 button for the space.
11
Scroll to [Data Bearer] press the [Central Toggle Key].
Select [GPRS] and then press [OK].
12
Scroll to [Access Point Name], press [Central Toggle Key].
Enter [general.t-mobile.uk] and then press [OK].
13
Scroll to [User name], press toggle key.
Enter [user] then press [Ok]
14
Scroll to [Prompt Password] and press the [Central Toggle Key] until it says [No].
15
Scroll to [Password], press [Central Toggle Key].
Enter [wap] then press [Ok]
16
Scroll to [Authentication] and press the [Central Toggle Key] until it says [Normal].
17
Scroll to [Homepage], press the [Central Toggle Key]. Push the toggle key to the right to enter text after the http://.
Enter [wap.t-mobile.co.uk] then press [Ok]
18
Press [Options], scroll to [Advanced settings] then press [Select]
19
Scroll to [Phone IP address] then press [Select]
Ensure this is blank then press [OK]. It should then say [Automatic].
20
The following items should be left blank:
Primary name server
Second. Name server
21
Scroll to [Proxy serv. Address] and press the [Central Toggle Key].
Enter [149.254.201.132]. Press [OK]
Note: use the [1] key to enter the dots
22
Scroll to [Proxy port number] and press the [Central Toggle Key].
Enter [8080]. Press [OK]
23
Press the [Back] key twice
24
This will take you back to [Default Access point]. With [T-Zones GPRS] highlighted press down on the [Central Toggle Key]
25
You will now be in [Settings]
26
Scroll to [Show Images] and press the [Central Toggle Key] until it says [Yes].
27
Scroll to [Text Wrapping] and press the [Central Toggle Key] until it says [Off].
28
Scroll to [Font Size] and press the [Central Toggle Key].
Select [Normal], then press [OK].
29
Scroll to [Default encoding] and press the [Central Toggle Key].
Select [Automatic], then press [OK].
30
Scroll to [Cookies] and press the [Central Toggle Key] until it says [Allow].
31
Scroll to [Conf. DTMF Sending] and press the [Central Toggle Key] until it says [Always].
32
Scroll to [Wallet] and press the [Central Toggle Key] until it says [Off].
33
Press [Back]
34
With [t-zones GPRS] highlighted press down on the [Central Toggle Key] to access the t-zones WAP service.
35
The message appears "Connection to Server is needed. Connect?"
Press the [Yes] key.
Hope this helps
