P900 does not update Outlooc 2003 calendar
1 replies · 2,910 views · Started 21 April 2004
Hi!
I have installed the latest software and firmware for P900. All sync from Outlook 2003 Calendar works fine. New entrys in the phone calendar sync fine. Changes in the phone calendar or deleting of an entry does not work. When I delete an entry in the phone calendar and start sync, the sync dialog shows "Deleting item 1", but the change is not made to Outlook.
Anyone now how this can be solved?
Thanks.
have you seen the sync options when you right click on the p900 icon in the system tray bar? because you can change the permissions on that, whether the phone writes to the computer, or the program overwrites things on the phone, there is also an option of whether you merge the two together, or things like that
