I have found an offered that is intriguing me...
a 7650 cheaper than a 3650 - is it worst ?
i wanted to buy a 3650 - but i knew 7650 is way better and when i saw the price i remained still... not knowing what to do
sp what should i do ?
7650 is not betterthan 3650. You maybe think it looks better but that is personal. The 7650 is starting to get old and the main problem is it has no MMC support. So you only have 4MB memory, thats it. For me thats reason enough to dont buy it. a smartphone with only 4MB is kinda useless. 3650 also has better picture quality. Or take a look at the 3660, it has a better screen and a normal keypad. The 6600 is even better but more expensive though. If i were you i would not consider the 7650.
The 7650 is one of the greatest smartphones i've ever used but like RoYaL21,its too old.Get something newer.
do you think a 3650 is too old too ?
i think i`m going to buy one - it has a year since it has been released - is that too much ?
Like i said, maybe you should consider a 6600. Its the best Nokia Series60 phone at the moment. in June the 7610 comes out. If you dont have much money to spend, get the 3650 or 3660. I dont say the 7650 is bad, but the lack of memorycards limits its functions.
Lower price class: 3650 or 3660
Higher price class: 6600
Or wait till the end of June for a 7610. About 500 Dollar/Euro.
IMO,the SX1 is better then the 6600 and if i were you i would probably get the N-Gage.The 3650,3660 have RAM problems.
It's strange, but here the SX1 is the most expensive, followed by 7650 (which is still virtually the same price it was when it came out), 6600, 3660, 3650. In fact, the 3650 is about half the price of a 7650!
For me, the keypad and looks of the 3650\3660\SX1 are off putting, and the 6600 is just too small (I have huge hands). The 7650 would still be by far the best Series 60 phone if only Nokia would produce an updated version with a decent amount of RAM, SD Support and proper Bluetooth. But that isn't going to happen.
I didnt mentioned the N-Gage cause i thought you prefer a camera phone. But the N-Gage is also a great phone. If you dont mind that you only have 4Mb you should get an 7650. Its your choice, but i still advise to get something better. BTW also the 7650 has RAM problems.
Not as much as the 3650/3660.Opera worked excelent on my 7650 on the 3650 it was a different story.
