A beta release of Opera 6.20 for S60 is now available from http://my.opera.com/forums/showthread.php?s=&postid=521914#post521914.
Please post your feedback in the MyOpera forums or in this thread.
Dag Olav Norem
Opera Software
Dag Olav Norem
Opera Software
Good stuff. Been using Opera on my phones for 1.5 years now, and I truly find it to be the best mobile browser around. I've just installed the new version, and have some initial impressions. I'll report back again when I've tried it some more.
The new Home page looks much better than the previous version. It's less "messy" now and easier to navigate. However, right after I installed and first loaded Opera 6.20, the Home page didn't show up correctly, but after I opened a web page and then went back to the Home page it was fine. And now when I exit and restart Opera it's displayed correctly. It might just be a small bug upon the first launch, I'm not sure, I guess you'll have to wait for more feedback to find out for sure. Another strange thing (bug?) about the Home page is that when you highlight a menu item from the top it's unreadable once highlighted, but as you scroll down to the bottom menu item they get clearer, and the last item is perfectly clear. I've attached a couple of screen shots to illustrate this.
It does seem to perform a little better now, faster, better formatting. The new 'Delete private data' as well as the 'Tags' option are both very welcomed additions.
A few suggestions, and things I find very annoying in both this and the previous S60 version:
-The annoying thing first. When I already have an active Internet connection and want to open a page in Opera, Opera will then just close my active connection and sometimes not even open the page I selected (even if it is the very same connection I want to use). So I then have to select to open that page two times. First for Opera to close my already open connection and then for Opera to actually start loading the page I have selected. This is annoying. I don't see why Opera can't just use my open connection? I have even set it to use the default connection in 'Settings'. This was never an issue in the UIQ version. I really hope you will correct this.
-Navigating. The new 'Tags' function seems very useful, but I haven't had a chance to test it out just yet. However, I have a suggestion that you enable some sort 'speed scrolling' when you hold in the cursor either UP or DOWN.
-Fonts. Please give us some font changing options, like in the new UIQ version. It would also be nice with multiple windows, although I'm not sure most S60 users would need/use it. There's also the RAM issue in phones like N3650 etc.
That's all I can think of for now, but I'll report back later if there's more.
Another great release!I can't add anything to the buglist,i had exactly the same problems as Raven except for the:
However, right after I installed and first loaded Opera 6.20, the Home page didn't show up correctly, but after I opened a web page and then went back to the Home page it was fine.problem.
One more issue.I can't seem to login to the wap version of this forum: http://wap.allaboutsymbian.com/forum/ .I get a incorrect Username or Password error.I'm pretty sure i'm typing it right because i logged in the www version of the forum without any problems.
Ghost,
I think that's a problem with this site's WAP version, not with Opera itself. I already reported this in the Admin forum a little while ago here. I guess Rafe will have a look at it when he gets the time...
Maybe,but i just logged in using the builtin browser and ttemulator.
On Symbian OS 7.0s (6600 and newer) this is not a problem as it supports multiple connections.
Problem is that noone has ever tried that freetype.dll on S60. We experimented a bit with it, but could not get it working. If any other developers out there know how to solve this please let us know.
We are looking into some other alternatives, but even if they work out it will likely be some time.
donpedro wrote:Thanks for the screenshots, very helpful. Are you using a 3650? We've mainly tested on devices with 64K colors, I suspect that may be the reason we have not seen it.
Oh I see. I am using an N-Gage (4096 colours).
We had a lot of problems with people who would have a WAP or MMS connection open and then start Opera. The browser would then use that connection and stay at 0kb downloaded, appearing to do nothing. Since it is not possible for the browser to know what connection is already open we implemented it so that Opera will only use connections which have been initiated by Opera itself. So this is a "feature" - the best of two evils.
I understand, but shouldn't Opera still use my default connection when I have set it to do so in 'Settings', and also set that default connection to be my GPRS Internet connection? This is a real problem for me, and I'm sure for other users as well. As I am constantly connected to GPRS Internet using other programs such as IM messengers, and quickly want to look up something in Opera, the process of first closing my IM connection and then starting a new one in Opera becomes tedious. I used the 'Doris' browser for a while and this was never an issue there... Doris would recognize my active connection immediately and use it. Doris is of course an inferior browser compared to Opera in many ways, but being able to_quickly_open a web page is perhaps the most essential thing about having a mobile Internet browser.
A solution to this is to always have Opera open and active, but that is far from a perfect solution.
Couldn't you just make Opera recognize a "faulty" connection such as WAP/MMS, and respond with an error explaining that Opera can't use the current connection? I know I'm oversimplifying it, but surely there must be a solution to this?
About fonts, I understand. Multiple windows would be nice for us N-Gage users where RAM isn't such a big issue though. Shouldn't really be an issue for 6600 and SX1 users either, just for x650 users really.
Anyway, many thanks for such a great browser, and it's nice to see that you are listening to the users and constantly looking to improve an already terrific mobile browser! 😊
Raven wrote:Oh I see. I am using an N-Gage (4096 colours).
This is a real problem for me, and I'm sure for other users as well. As I am constantly connected to GPRS Internet using other programs such as IM messengers, and quickly want to look up something in Opera.
I have one comment.
On the home page, if you switch to full screen, then back, then full screen once more the tab on the right hand side is out of sync. It stays in the same position even through the screen size has changed.
It only happens on the Opera home page, If I change it to a page I created myself it is then OK.
Will the 7610 be shipping with this broswer?
Just wondering as the Keyboard Shortcuts has an image of one next to it!
badger wrote:On the home page, if you switch to full screen, then back, then full screen once more the tab on the right hand side is out of sync. It stays in the same position even through the screen size has changed. It only happens on the Opera home page, If I change it to a page I created myself it is then OK.
The position of the tab changes when there is new scroll information. But since it is not possible to scroll at all the tab does not get new coordinates. The correct behavior would probably be to have no tab at all...
Will the 7610 be shipping with this broswer? Just wondering as the Keyboard Shortcuts has an image of one next to it!
