N/A wrote:There were about 8-10 million Symbian OS phones sold last year (if I remember correctly).Most of them have Bluetooth.
There will probably be at least twice as many sold this year.
Manufacturers make their phones in batches where there probably won't be a single Bluetooth ID range for any single model, nor any single manufacturer even (as they will have multiple blocks and consume them in any which way they've decided to do).
In other words, you're not likely to detect any patterns with any accuracy from the few thousands of readers here (of which probably only a very small percentage will send you the info anyway).
In other words, I'm sorry, but I don't believe your approach is very realistic.
Anyway, it probably won't help much, but if you contact the Bluetooth SIG (Special Interest Group), perhaps they can tell you what blocks are allocated to which companies.
Instead, it might be more useful to you if you research OMA DM (Open Mobile Alliance, Device Management) UAProf (User Agent Profile) and Platform ID stuff (UIDs allocated for different Symbian OS releases, different versions of Series 60 and different models, etc.).
E.g., Forum Nokia has a document that lists the Series 60 version and Nokia Series 60 phone model specific UIDs.
Thanks for the heads up. The other information is worthless, because a remote server scanning for phones using Bluetooth can only pull up the Bluetooth ID (if it's even discoverable) -- I will ask the SIG however if such data exists, thanks for the advice. I'll probably just have to have people with smart phone send a .txt file with "7650" and then parse it, collect the BT address, and send the proper client back ...
Anyway, thanks....
