Hi people, I've not had my 6600 for more than a few days, and all was well with the standard 32mb MMC card. I decided an upgrade was in order and purchased a 512mb MMC cardm, however the phone just doesn't recognise it.
I've popped it in the card reader connected to my pc and can save files to it and format it (FAT16) easily, however when I put it back in the phone it's just not recognised.
My firmware version is v4.09.1 - 26/02/04 - NHL-10.
Any ideas how I can get this thing operational? :frown:
Thanks lots,
well it cud be that the mmc is not supp by the phone. wht brand is the mmc ?
The card says iConnect.
I purchased it here, and as the seller said it works well with Nokia 6600, and the fact the seller has such a great feedback rating, I was certain it would work.
Are there any measures I can take to solve this?
I believe the max size supported for the 6600 is 128mb 😮 .
There may be a way to fool it - but I havn't heard of one. :frown:
Good Luck
En Croute
en_croute wrote:I believe the max size supported for the 6600 is 128mb 😮 .There may be a way to fool it - but I havn't heard of one. :frown:
Good Luck
En Croute
No its not 128MB.Just look at the Tested MMC Cards thread and see how many people have successfully used 256 or 512MB MMC's.For the zilionth time,some brands work and some don't.
GhostDog wrote:No its not 128MB.Just look at the Tested MMC Cards thread and see how many people have successfully used 256 or 512MB MMC's.For the zilionth time,some brands work and some don't.
Ahh - RTFM, or should that be RTFF :redface:
Apologies.....
Good Luck
En Croute
Well, for sure the 32MB MMC that came with the 6600 worked....
Gibson wrote:The card says iConnect.I purchased it here, and as the seller said it works well with Nokia 6600, and the fact the seller has such a great feedback rating, I was certain it would work.
Perhaps u can try to format using ur Card Reader by using FAT. Then format again using ur phone. Was told by a shop that if cant access then format using PC then Phone but remember don't use FAT32 use FAT.
I tried formatting the card with the reader, and that worked, however when I put it in the phone is either said card corrupted, or no card inserted. When it said card corrupted I had the option to format. So I did (on the phone) and then it asked me to name the card. I entered "6600" however it said that the action couldn't be performed, then continued to tell me that there was no card inserted. Now, even when I put the card in the reader, it tells me that there was a card reading error.
I'm a sad boy now 😞
its not only locked to 128 . after changin from 4 128mb cards i just got a 256mb microsim. works gr8
Gibson wrote:I tried formatting the card with the reader, and that worked, however when I put it in the phone is either said card corrupted, or no card inserted. When it said card corrupted I had the option to format. So I did (on the phone) and then it asked me to name the card. I entered "6600" however it said that the action couldn't be performed, then continued to tell me that there was no card inserted. Now, even when I put the card in the reader, it tells me that there was a card reading error.I'm a sad boy now 😞
I bought 2 X 256mb TwinMos MMC and one of them have exactly the same prob. I went back to change and thats what the shop owner told me..perhaps u go and exchange a new one as they provide warranty rite.
glay78 wrote:I bought 2 X 256mb TwinMos MMC and one of them have exactly the same prob. I went back to change and thats what the shop owner told me..perhaps u go and exchange a new one as they provide warranty rite.
I hope so dude, I'm waiting to hear bacl from the seller.
Fingers crossed eh? 😞
Gibson wrote:Hi people, I've not had my 6600 for more than a few days, and all was well with the standard 32mb MMC card. I decided an upgrade was in order and purchased a 512mb MMC cardm, however the phone just doesn't recognise it.I've popped it in the card reader connected to my pc and can save files to it and format it (FAT16) easily, however when I put it back in the phone it's just not recognised.
Thanks lots,
hi
i had this same problem.... put the old memory card in the reader and check what it was formatted in by right clicking on the device. you must format the new mmc in the same format or it will not read it.
many thanks
dan
hey i got the software which can format memory card from the computer itself
please try this "http://www.tomdownload.com/utilities/security_encryption/flashDrive_crypto.htm"
best of luck it's F@ms'hh!!!... (
please mail me for more software song's etc [email][email protected][/email])
