Better sms program that can store inserted words?
1 replies · 2,316 views · Started 24 April 2004
hi,
does anyone have an sms program to recommend that is better than the built in one? would be good if it is able to store inserted words. find it troublesome having to insert words again and again after i replace my battery...
thanks...
The words you insert into the dictionary should stay in the phone after you remove the battery.
