Hi all,
I'm trying to edit one of the default themes (Blue) but don't know where they are placed. I had a look around this forum and got one location like: c:\system\data\themes\default� but I haven�t got any thing there. I don�t have any directory called as �default� under �c:\system\data\themes� location. Any idea where else it could be?
Thanks in advance.
I'm not sure, but I think they are on the Z drive, and you can't edit files on the Z drives. You might be able to copy them to the C drive and edit them from there, but the original ones will always stay
Delta737 wrote:I'm not sure, but I think they are on the Z drive, and you can't edit files on the Z drives. You might be able to copy them to the C drive and edit them from there, but the original ones will always stay
That's fine too but the problem is I don't have any 'Z' drive. All I have is 'C' & 'D' which, I guess, represent phone's internal and memory and MS Duo. Or am I missing something?
SEP900 wrote:That's fine too but the problem is I don't have any 'Z' drive. All I have is 'C' & 'D' which, I guess, represent phone's internal and memory and MS Duo. Or am I missing something?
Download this freeware app, and you'll see a Z drive (and an A drive too!)
http://my-symbian.com/uiq/applicati...ldAuto=14&faq=2
Delta737 wrote:Download this freeware app, and you'll see a Z drive (and an A drive too!)
Many thanks Delta737, for the link and your help. Thank you very much indeed!!!
