My New P900 Customized Leather Belt Case
4 replies · 4,838 views · Started 25 April 2004
Its amazing, Finally the perfect case for me.
You see I dont like the Brando and AIR something Case for the P900 because for one the are Leather Jackets which is made to be on the p900 all the time even when you are using it.
And If even I would settle for the above mentioned cases because they have the DUO pockets which I think is essential, they are both uprite standing cases when you clip them on your belt, I prefer the sideways(landscape) leather case because the upright ones easily get tucked off the belt one we sit down 😞
All the other Landscape available cases like krussel etc.. dont have DUO pockets, except the jacket type case.
What I want is just an ordinary leather belt case with DUO pockets and volume/headset connection and battery charging provisions. I like using my phone and feeling my phone as it is so I wont have a hard time texting. I know others would worry what if my phone would fall, with the jackets they protect the phone, well, I have a strap attached to my phone so everytime I use it I put it on my risk so that if I do accidentally drop it, it wont fall 😃 And the strap is free on al p900's (Although im using an extra one from my old t68i)😃
So I had one customized 😊 It is unbelievably so usefull!!
<Check out pics below>
I think I will have another one made this time with a small pocket on the right side (top of the phone part) so I will be able to put my 2.5mm-3.5mm adapter. If you are in the Philippines let me know if anyone is interested, PM me 😊
Attachments: New Casing with Duo Pouch-wexplntn.JPG
Hehehehe, actually I was thinking of having a small SE button made and stick it there right in front 😃 They als have sting rey leather if you want 😃
Muzikfreakah wrote:They als have sting rey leather if you want 😃
I like that...
but guess you need this phone to go with it 😃
