I have a few scratches in my phone's screen. 😞
Is there any cleaning product to them, or am i going to have them forever? is it possible that nokia changes the front cover?
Anyone with the same problem?
May you can try , products used to remove scratches on spectacles.Check with the specialist. :roll:
thanks but not much of a help... :cry:
Have you scratched the screen, or the plastic?
It may not be the actual screen you have scratched but it could be the plastic protection film you have scratched
did you remove the plastic film from your phone when you got it?
you could go to a pet shop where they sell fish tanks. They sell stuff for removing scratches on the glass of the fishtanks. You should be able to use that on your nokia display.
Not too sure about name/brand of the stuff. But some phone shops seem to sell a kind of 'wax' you have to rub on your display. Scratches seem to be less or even not visible anymore. Same thing is used for car scratches I believe. Something to do with crystals and reflextion of light... 8)
thanks for all the ideas.
of coure that i removed the plastic (although i regret it... :cry: )
i'll try to make it. Thanks once again
hey good luck mate, I know there snothing worse then a scratched screen man, ive been there before.
