On all of 4 N-Gages i've had, the radio stopped working after saving a radio station. Does anyone know what is wrong.
My radio isn't working anymore!
I assume you get "App. closed FMRadio". That's because you hit 'cancel' mid save. There's a bug that makes the radio stop working after that.
You'll have to reset your N-Gage to factory defaults. First backup the device to an MMC card using Tools/Memory/Options/Backup device mem., then type *#7370# to reset the device. You will have to enter the unlock code, which by default is 12345. The device will take a minute to reset. Then restore using Tools/Memory/Options/Restore from card.
NO You do not need to reset your phone!
Just press the 5 button while starting the radio, go back to your list of saved stations and edit the name of the radio station you saved but left the name out. This error occurs if you dont complete the save process - enter the name of the station.
inee
Nokia Service Center
I just got my ngage reflashed my nokia service center. when i click the radio button(with the headset plugged in)..the screen simply fades away and the phone restarts...Please help!
Unregistered2 wrote:NO You do not need to reset your phone!Just press the 5 button while starting the radio, go back to your list of saved stations and edit the name of the radio station you saved but left the name out. This error occurs if you dont complete the save process - enter the name of the station.
inee
