Does Psiloc's "Where I Am" work with 6600?
2 replies · 1,839 views · Started 26 April 2004
I've searched the "Apps that work and don't work" thread, couldn't find it so...hasn't anyone tried this software?
http://www.handango.com/PlatformProductDetail.jsp?productType=2&optionId=1_4_2&jid=69E7CF5F4AF1B51D468536CE44C229X5&platformId=4&osId=298&siteId=1&productId=96754&advSearch=true&sectionId=0&keyWords=psiloc&catalog=20&txtSearch=psiloc
I downloaded the trial but always get the "App. Closed" error when it's installing the sub-program "miniGPS.exe". My ROM is V3.42.1, 16-10-03, NHL-10
Can anyone get this to run on the 6600?
Thanks for the input!
Kajjy wrote:Hi,
i haven't personallly use it but according to the website
u can use this product on any version of 6600
for mor information log on to
http://www.psiloc.com/?id=prod&nrp=104
Vicky wrote:i haven't personallly use it but according to the website
Thanks Vicky - that's precisely why I'm asking if anyone else's been able to run it because it supposedly supports the 6600 but I've been getting errors with it, so I'm wondering if it's just my 6600, or the program.
The thing is that if you look at this link I gave for Handango
The top says Psiloc Where I am for Nokia 7650/3650/3620/3660/6600/N-Gage, Siemens SX1, Sendo X by Psiloc Mobile Solutions (PsiNT) but the bottom says Nokia 3600, Nokia 3650, Nokia 7650, Nokia Series 60 so I'm wondering if they actually tested it with the 6600, or just simply assumed that it works with the 3650 and 7650 and therefore, most likely also works with the 6600 - another Series 60.......
