hello to all plz your help
6 replies · 1,214 views · Started 26 April 2004
hey all!
iv got prob when i try to install sis software not all of the prog but few of them when i put them in my 6600 the sis and i prees install its like nothing happend it return back to the sis i cant install them its like im presing on the sis and nothing hapeend plz your help
thanks 😊
phantom wrote:hey all!
thanks 😊
if ur prob is this.
sometimes when i trasfer some messages(sisfile) to mobile they work only once
accoding to me there are few file which work more then once
but acc to me
when we trans sis file and we install that file and afterward when we go and open the file its look that nothing is happen we stay there only whear we were.
Try double clicking the sis file on the pc with phone connected,this will by-pass self installation and install straight on to your phone. 😊
elton wrote:Try double clicking the sis file on the pc with phone connected,this will by-pass self installation and install straight on to your phone. 😊
this is the best way to transfer the sis files
and reduce the chance of memory blockage.
Vicky wrote:this is the best way to transfer the sis files
Agreed. This is the best option....
Vamp wrote:Agreed. This is the best option....
Right, although direct installation from PC can bring some problems: uninstalling will be harder (had to do it manually with FExplorer)
Lenepyhe wrote:Right, although direct installation from PC can bring some problems: uninstalling will be harder (had to do it manually with FExplorer)
Same uninstallation steps.... Wat's the diff?
