Hi all,
My p900's battery ends in approx 2 days 😮 with average phone usage, sync etc. If I play some java games the time reduces 1.5 days or more less.
Is this normal ?
Hi all,
Is this normal ?
Well it's not very strange. With very little usage I can get 4 days out of it, but usually it's around 2 days...
try a Full charge, Restart, then use it just for phone calls, and it should work for 4-5 days (I mean 30min/day MAX)
as if you enable bluetooth you'll loose %40 of the regular battery life
and if you activate the Camera you'll loose %75 of the regular battery life
so you'll have to make sure you close all your app.
atakan wrote:Hi all,My p900's battery ends in approx 2 days 😮 with average phone usage, sync etc. If I play some java games the time reduces 1.5 days or more less.
Is this normal ?
Charge battery fully, then restart so no programs is running in background. Some apps even activate when you turn on the phone, so check what you have installed.
My phone can hold for a week or more if i only use the phone part. As mention earlyer bluetooth etc will power down your phone fast.
SE promise 400 hours standby, this is correct if your signal is strong and the phone is not used at all 😊
Also if you move around in areas that has bad signals, power will drain faster.
If I bought a p900 , I've to use some PDA functions that means i should accept 2 days 😊
thanks for all guys
