Here is a link that I have found that will enable you to change your case without all the hassle of causing more damage than good to your trusty 6600 😃
Injoy
p.
Injoy
p.
pulsta wrote:Here is a link that I have found that will enable you to change your case without all the hassle of causing more damage than good to your trusty 6600 😃Injoy
p.
bcoz nokia havn't said that 6600 comes with xprees on covers
it is the repair cover.
Hi Pulsta,
Can't access the link! Did you by any chance save a copy and if so could you send it to me?
Cheers.
thehandbag wrote:Hi Pulsta,Can't access the link! Did you by any chance save a copy and if so could you send it to me?
Cheers.
following is the link
http://www.gbnetwork.co.uk/6600/disassembly/
be beware u may lost ur warranty
and may u make harm ur phone body
u r using the above link at ur own risk
Note that you need a special tool kit to open the phone to reduce the likely hood of damage. Mines ordered up and winging its way to me just now. Cant wait to ditch those drab covers for some see through ones! 😊 :icon14:
