changing the menu fonts
4 replies · 4,767 views · Started 27 April 2004
Is there a way to change the color of the fonts used in the menu?
Apparently it's not possible with any theme editor, but maybe there's a way of doing this by changing some value in the system?
Hmm I'm not sure if this is applicable to you or not but one of the ways of getting the 6600 to display Thai Fonts is to put a t9u.dgr file in the System Folder. This basically makes the 6600 use an alternative font. In my case, I used this font set called "set3v3.gdr" - a Thai + English Font. This changes ALL your system fonts.
You can remove it as well but I only have access to Thai character sets which has a side effect of replacing a number of little used characters, like # with Thai characters.
