Symbianthemes.com
7 replies · 4,641 views · Started 27 April 2004
Please can someone advise, I have a problem downloading anything over 180kb on symbian themes wap site. Downloading comences however once at 100% a message System Unable to perform blah blah come up (very fustrating) this is fine for all themes under 180kb.
Please can someone advise if they have the same problem or give advice on how to rectify this situation.
Cheers.
Your WAP gateway (I presume you're using WAP?) may impose a limit on the maximum file size you can download.
Cheers,
How do i go about finding out the max Kb i can download. Its WAP GPRS i am using to download the themes.
Are you able to change this so i can download larger files. :?
Cheers..
Howdehow,
I saw that you up-loaded on zedge.no the "18Th hole" theme made by Elton and it says that the author is masterb, you should correct that mate, it's not fair :icon13:
Elton,
Appologies, i did'nt know how to find the original Author, was not trying to steal any limelight..
Thats ok mate,
No need to apoligize,im sure this is the case with most themes that are uploaded with the wrong author.
howdehow wrote:Cheers,
Cheers..
I think you'll have to ask your operator.
