Reset Phone Settings, Now App Manager empty...
1 replies · 3,341 views · Started 27 April 2004
Hello!
I was having problems with my phone at one point, and called T-Mobile. They suggested to reset the phone to original settings which I did....
Now my app manager file is empty, though I have a TON of programs installed on my MMC card. How do I get it to see them again? Also, a lot of my programs need to be re-registered (damn!), LOL.
Please Help!
jettrue wrote:Hello!
Please Help!
When u do a format in my experience, it might be a good Idea to format the MMC too. I formatted mine just a few days ago and only kept the system/mail folder because thats where I store my GPRS/MMS configurations and my texts. The rest I wiped off.
You didnt describe your problem before you did the format, maybe the problem is with some softwares installed on your MMC. One app that fucked my 3660 was the kikokiko game, not intended for 3660 but i gave it a try and i got screwed.
Just format and re install the programs u need. Thats the better solution.
