Picture Messaging - Mobile to Mobile
2 replies · 2,129 views · Started 28 April 2004
I have a 6600 on FIDO GSM netowrk in Canada. I tried getting mobile to mobile picture messaging working but can't get it going. I also have set up email and web access etc - and those work perfectly.
FIDO sent me the settings via SMS and I acepted them but they do not seem to work. The multamedia messages just sit in my outbox and finally time out - so clearly I am not connecting properly. I have had the FIDO techs on the phone but they can't solve it as the 6600 not supported at the moment.
Are there any FIDO users out there that have got theirs working?
Bingo wrote:I have a 6600 on FIDO GSM netowrk in Canada. I tried getting mobile to mobile picture messaging working but can't get it going. I also have set up email and web access etc - and those work perfectly.
Bingo,
I'm afraid I have no experience with the FIDO network, but I have experienced MMS (picture) messages sitting in the Outbox and then failing for no apparent reason on UK Networks.
I fixed this problem by removing all spaces in the phone numbers for my Contacts. I always put numbers in with a space, i.e. <area code><space><number> and it was the space that was stopping the messages being sent out.
If this helps you, then great, if not, then I tried, good luck!
BSK
In the UK I�ve had problems with sending MMS on Orange and O2. Turns out in both cases some Idiot had forgotten to enable my account properly. If all else fails rant at your operator.
