hello i bought recently a nokia 6600, well it is realy a good gadget but i have a problem : after installin the Pc suite & rebooting it asks me to fill in the name of the phone & it doesn't accept the new name (it is the first installation) does anyone had the same problem ?? :?
Thanks .. 😎 Malek ..
pc suite problem ..
You must install the Pc Suite into the default directory.
C:\Program Files\Nokia\PC Suite for Nokia 6600
You have installed it into a different drive maybe? Uninstall & reinstall using the default.
