Backup of Tools/Applications
3 replies · 1,724 views · Started 28 April 2004
Hi !
:hmmmm:
Is there any possibility to make a backup of the software which is installed in the /Tools/Applications folder ?
I got 2 applications in there i've downloaded via VodafoneLive, but already deleted the initial installation file.Now i need the space on the phone for some time, but don't want to pay to download the apps afterwards again
I just made a full phone backup using the Nokia PC Suite, but browsing through the filestore.dat.txt i can't find the stuff i've installed in there. Only things like photos, the videorecorder and all software which is installed in the 'root' folder.
thanks for any help ^^
Anotsu
Check out the text file BackupExclusionList.dat in the PC Suite installation directory on your PC. By default the Java/MIDP files are excluded from being backed up.
N/A wrote:Check out the text file BackupExclusionList.dat in the PC Suite installation directory on your PC. By default the Java/MIDP files are excluded from being backed up.
thx !! :icon14:
worked fine !
