Does anyone knows if someone will develope MMS program for 9210?!?
MMS?!?
There have been discussions about MMS in this forum and in the Multimedia forum and in one of the recent discussions forum member "akn78" from Sweden mentioned that he was planning to develop something. Haven't heard anything since.
If you use the search function in the forum you should be able to come across all MMS topics so far.
HTH,
Tilman
you need GPRS to send and recieve MMS, so forget it 😃
[quote="TooSpecial"]you need GPRS to send and recieve MMS, so forget it 😃[/quote]
Who told you that? :evil: HSCSD is enough, and even normal GSM data works. It is just a matter of speed. Most operators that have already launched MMS services, restrict the max. message size to 30k, which is not too big to send via GSM data. It is just more convient to have GPRS, nothing more!
