how to remove carrier branding?
9 replies · 10,222 views · Started 29 April 2004
I bought an N-Gage from EB last night, and it is branded for T-Mobile. I use AT&T.
Is there a way to remove all the T-Mobile specific elements from the N-Gage? I'm assuming that even the factory reset code isn't going to remove that stuff, but maybe I'm wrong. 😊
In particular, I'm looking to get rid of the way that services is called "T-Zones" (as when used on the softkeys) and T-Mobile ringtone(s), along with miscellaneous settings.
Thanks for any info.
--Jason
The only way to go is to reflash the firmware with some country specific one or one for AT&T (if exists) for example. Don't expect to have more free mem though.
Iva been having the same problem. I just bought an N-Gage and put in my cingular sim card. I know for a fact that cingular works on N-Gage, but the problem is the T-Mobile crap that was already on the N-Gage. How do i get the wap browser to work on my engage? and how do i remove all of the T-Mobile crap off of it?
I'd say you would need the phone reflashed with a sim-free & unbranded firmware.
You'll need to locate a mobile phone store that can do it for you.
Really, never realised they would be involved with that sco2001.
Don't think they have branches outside the UK yet, as I assume riftweaver is in the US/Canada, being on AT&T.
Unregistered312 wrote:Iva been having the same problem. I just bought an N-Gage and put in my cingular sim card. I know for a fact that cingular works on N-Gage, but the problem is the T-Mobile crap that was already on the N-Gage. How do i get the wap browser to work on my engage? and how do i remove all of the T-Mobile crap off of it?
cingular wont work on n-gage,either will at&t
only tmobile sim cards will work on n-gage
i have tried :frown:
i tried with at&t and cingular and both didnt work
not sure about virgin or us cellular or sprint
To remove the oplogo on my ngage. 1st I have t-mobile usa if you are in another country another source is needed for the ota oplogo. I goto me43.com got an account (free of course) they have to test your capabilites of your device N-gage is not listed pick the 3650, they do this via sms. so 1st you will be required to confirm the text message with a simple number. Next is custom service capablitity testing again now here you are offered 2 options select with a picture not a tone. You will recieve a ota oplogo select yes to replace your existing logo. After that you have released the hold on your carrier name all you have to do is use 1 of 3 programs to replace it. seleq, fexplorer, or opman. I prefer opman its more user friendly. take a 97 x 25 (width x height) image and replace it have fun it works great this way and this procedure will have to be repeated everytime you format your phone.
