nokia 6600 turns off automatically
5 replies · 3,839 views · Started 30 April 2004
hi all,
i got a 6600 from dubai , its made in finland so i thought it will be good . Now after 3 weeks a problem started . When my cell is in stand by mode , i.e. when i m not using it , and when i see it after some 2 hrs , its turned off . Then when i press the power switch the cell starts , and the battery also shows full , as it was before .
I dont know wat is the problem , i contacted Nokia by email . They hav no answers .
Can anyone gimme any idea
i read on some site some code *# somethin # .... shd i use it to format .... and if i format will the operating system 'symbian' remain in the cell ... if not how will i install it ...
what do u think can be the fault .... as i dont consider Nokia to be a bad company
amigos
amigos007 wrote:i read on some site some code *# somethin # .... shd i use it to format .... and if i format will the operating system 'symbian' remain in the cell ... if not how will i install it ...
amigos
There's a special Thread for formatting, have a look.
hi , i formatted the soft way using *#7370# .. some 12 hrs back ... n till now the cell is working fine .... hope it does work fine .....
But what can be the problem ... how can a cell switch off on its own ... wat causes this .... y doesnt anyone hav its answer ....
Formattin although is a solution ... its not a cure
amigos007 wrote:hi , i formatted the soft way using *#7370# .. some 12 hrs back ... n till now the cell is working fine .... hope it does work fine .....
hii this is soft format
you should have try hard format
1 transfer your data into your pc.
2 switch off your phone.
3 press green button + * button +3 button together
and then start the phone don't remove your hand from the butttons
4 and when u see formatting on the white scrreen leave it
be ensure that u battery is full before doing this
for more detail read the formatting thread.
