Startup MP4
2 replies · 2,014 views · Started 30 April 2004
Is it possible to change the wav/mp4 startup files - they're in the A drive/sysdata?
In hope. :?
This question has been asked several times before, including once by yourself (?). The answer is STILL no. It is in READ ONLY memory.
Justin wrote:Is it possible to change the wav/mp4 startup files - they're in the A drive/sysdata?
In hope. :?
Hallo Justin,
I have found some instances describing this process for the P800 ( Create a diredtory by the name of C:\Sysdata and copy Startup.mp4 and Shutdown.mp4 there. ) Alas this does not seem to work for the P900.
On the other hand, the upgrade process for the P900 rewrites the ROM area when performing software updates, so there must be a way to achieve this programmatically via the cradle and PC.
Shouldn't any of the clever programmers out there come up with a solution to this ?
Hoping with you for a solution, Casual 😎
