When i try to send the mp3 file to my 3650 with nokia apps, the file change to .wav... I dont wont to change file, because your size is much bigger than MP3...
How I could send to my cel phone the Mp3 file?!
Noboby can Help me?!
I Just trying to send MP3 files to nokia, but I cant because the nokia apps change to WAv and the Mp3Go dont read the WAV fila...
HOW I COULD SEND MP3 TO MY NOKIA....???????????????
People are probably not answering because this question has been answered 1000 times in the forum and a simple search before asking would have given you the answer, or a quick skim of your manual would give you the answer, or a quick skim of your settings in PcSuit and you would have seen the tick box to stop it converting .3gp files into .wavs
Welcome to the forums, but please use the search button 😊
Will
willbrady wrote:People are probably not answering because this question has been answered 1000 times in the forum and a simple search before asking would have given you the answer, or a quick skim of your manual would give you the answer, or a quick skim of your settings in PcSuit and you would have seen the tick box to stop it converting .3gp files into .wavsWelcome to the forums, but please use the search button 😊
Will
Thanks!
Will
THANK YOU VERY MUCH! I HELP ME A LOT... ITS MORE THAN EASY!!!
[QUOTE='[O_pSiCoPAtA]']When i try to send the mp3 file to my 3650 with nokia apps, the file change to .wav... I dont wont to change file, because your size is much bigger than MP3...
How I could send to my cel phone the Mp3 file?![/QUOTE]
You need a SeleQ or eFileMan software to send the mp3 file to your cell phone.
[QUOTE=Sandman] Sorry i was mistake! I mean use SeleQ or eFileMan to send mp3 file from phone to phone. so from pc to phone use infrared software not PC SUITE.
