PCSuite will synch with Outlook so long as you use an Internet Profile. I am trying to synch with Outlook using an Exchange Profile and PCSuite always complains about a bad password. Nokia USA Tech Supp. tell me they have done it but it is unsupported and could not help. I have been able to backup/restore from the Exchange to Internet Profiles and synch from there but that is somewhat cumbersome. Has anyone else tried to solve this, even perhaps using something other than PCSuite. I spoke to Intellisynch but they say it does not talk to a 9290. Thanks in advance
9290 MS Exchange Synch
I think you can do it without add on software but we use Extended Systems XTND Connect.
This allows remote sync by dialing in as well.
See how you get on:
> http://www.extendsys.com/ESI/Products/Mobile+Data+Management+Products/
[quote="Stephen.Gazard"]I think you can do it without add on software but we use Extended Systems XTND Connect.
See how you get on:
> http://www.extendsys.com/ESI/Products/Mobile+Data+Management+Products/[/quote]
Interesting. Can you give us more details about the setup? PCSuite interfacing with Outlook is nightmarish, so I'd love to find out about alternatives.
Thanks much,
MB
If you send me your email address I will forward all the PDF information I have.
Steve
