Hi - I want to add data (my working shift pattern) to my mobile from MS Outlook. If i were to input it using the phone, it would take ages, thats why i want to do it this way. Is this possible? If so, can someone tell me how to do it in laymans terms. Much obliged.... 😃 :P 8) 😮
Transferring data from outlook to Nokia 7650
If your working shift pattern is entered on the outlook calender on your pc then you can use the nokia data suite that came with the 7650 to sync it with your phone. All you need to do is get your phone connected using either IR or bluetooth. I hope this helps. 8)
hmmm shame theres no option in outlook to mail it to your phone !
