Hi all,
This was the first attempt to make a theme for my own � very much the based on my PowerBook and decided to share my works with all, in case if like.
Below the link to have a look what I�ve done. Please feel free to make comments.
Hope you guys will like it!!!
http://homepage.ntlworld.com/santanu_das/p900/themes/
SEP900 wrote:Hi all,This was the first attempt to make a theme for my own � very much the based on my PowerBook and decided to share my works with all, in case if like.
That's great, well done. Installing it now. :icon14:
Looks like the file has got damaged - the P900 refuses to use it, saying it's not a valid theme...
Pity.
Love the look of this, shame it does not work :frown:
Hi, I was using the same one with out any errors. Right now I cannot test, coz the my 2nd P900 ( 1st one is lost :redface: ) cannot connect to the PC. I'll check once again and will re-post.
Many thanks,
SEP900 wrote:Hi, I was using the same one with out any errors. Right now I cannot test, coz the my 2nd P900 ( 1st one is lost :redface: ) cannot connect to the PC. I'll check once again and will re-post.Many thanks,
yup, fixed now. It looks like got currepted diring uploading. Just tesed on my P900, working fine and can be downloaded from the same location
Have fun, Cheers
