I keep getting this error:
01 May 2004 PM 10:17
|belboi 900| belboi 900 is low on memory. Please remove some data from the device and sync again.
Conduit belboi 900 generated exception NSSyncConduitException: belboi 900 is low on memory. Please remove some data from the device and sync again..
can't connect to the device to synchronize belboi 900.
I still have 9.2 MB storage memory, and at between 6.8 to 7 MB of system memory when I try to sync.
Does anyone else experience this problem or know how to solve it?
Hello,
Have you been able to solve this one? I'd appreciate hearing on it from you.
- Martin
Yeah, had to do it the hard way. Deleted all past appointments, then do a full sync. Quite a bummer. Seems an entry in the past appointments was corrupted or something.
I also had this problem.
Mine was the contacts db. I had to many large images. I used contact link to get them from the db, then I resized them, then used contact link again to put them back into contacts db.
I have discovered that this problem can be caused by long notes in entries in iCal. My guess is that the phone receives an entry with a big note, and sends a message back to iSync saying "No room!" - iSync interprets that as saying the phone's memory is full.
Once I Googled this discussion, I noted the comment about Address Book entries with big photos. While my problem was with calendar sync, that set me thinking, and I took a look at the entries added since my last successful sync. Sure enough, I'd imported an entry from Entourage (using the Sync iCal-Entourage script) that had an email message in it, and that had given me a long note. Once I deleted the excess text, iSync worked fine.
I've reported this to Apple.
