P900 Reminder sound inconsistent
2 replies · 2,922 views · Started 01 May 2004
Hi All
I have a P900, but the sound that is uses for reminders / appointments from your calender is not consistent. It will play the correct sound that I have set under Reminder in the sounds and alerts window for 90% of the time, but for the rest of the time it will play the default alarm sound or the previous sound that I have had selected for reminders!! Have any of you experienced this problem? Am I doing something wrong or is there a fix for this?
Also, how does one change the sound for sms / reminders for when you are in a call?
Please help.
Ronnie
if you have that sound saved on your MS Duo, and you change it from time to time, or you restart your phone with the Stick out, then the phone will set up all souns not found in the phone to the default sound to play, when the card (with sound files) is insertd it will load and play back again!
I believe this is your problem 😉
This is not my problem, but I have resolved it in the mean time, thanks.
