dear sir or miss
i have one problem
when i download jar file ( example fifa2003.jar) from internet and transfer this file from my computer to my phon(nokia3650) via infrared to my mmc root then i cant see any program or game application at my inbox messeage for install .
please solve my problem if possible
tnx
i have one problem about jar file
i am also facing the same problem with 3650. Pls help both of us
Basicly you should transfer the jar files to c:\installs.
Either via the PC-Suite Software or the filemanager.
(And keep a copy of the file on the mmc, so you can send it to a friend for example...)
Then just use the "Programms" -App in the main Menu to install the Jar.
This should do the trick!
