MMs Editor not working!!!Need Help...
2 replies · 1,815 views · Started 02 May 2004
Hello!!!
My Nokia 6600 is unable to create any MMS...
When I try to start mmseditor.app it simply doesn't start...Nothing happens!!!! I can't create or send any MMS!!!
Please Help!!!
Thanks!!!
Sorry to dig up an old thread.
My 6670 has had this problem for the last few months and its been bugging me, but i just figured out how to fix it!
Messaging > Options > Settings > Other > Memory in use
Change it to the one currently NOT in use then change it back and voila! problem fixed!
I've been having a problem with my 6600, Firstly you may have heard about the problem with the message tone (not playing one!) and the "1 new message" dialog not appearing.
Aswell as this problem I was experincing the same problem as you (not being able to create, edit...etc MMS messages). I've now solved this by formatting the memory card. however I think this will only work if you are using the card for message memory But i suppose it's worth a try even if your not.
If this works let me know, I always stick to using the memory card messaging, as I would much rather format a MMC card than perform a hard reset of the phone.
Mcguireuk
