Hi guys, I've made some bmp icons for which you can use for nokia 6600 themes. They are all 44 * 44 pixels and comes with the mask for transparency. In short, ready for use! Hope they are of use.
100s of Free icons for Nokia 6600 themes
I want those Blue ones exclusively! (did i spell that right?)
And maybe those BEAR Icons/stuff aswell!
Add me with msn: [email][email protected][/email]
Once i get some icons for my 6600 how do i install and change individual icons ? 😮
You don't. What you can do is to use the Series 60 Theme Studio to create or modify icons (and other bitmaps) in a theme, and then generate an installable version and use it on your phone.
The Series 60 Theme Studio is downloadable from http://forum.nokia.com/
Or install a theme with a nice set of icons,and go to the theme selection menu and 'edit' the theme you are using and set the icons for that theme to be used.
elton wrote:Or install a theme with a nice set of icons,and go to the theme selection menu and 'edit' the theme you are using and set the icons for that theme to be used.
FYI this can't be done with a 6620 😞
It cant be done with 7610 either.
