My First Theme
13 replies · 1,758 views · Started 03 May 2004
Ever heard of the "Windows 97 to Windows xp Programm conversion" PROBLEM?
Well it excist and i have it!
Please just post screenies here!?
remcokatz wrote:Ever heard of the "Windows 97 to Windows xp Programm conversion" PROBLEM?
I don't get your point????? :? :?
That wasnt very helpful was it.
There are a few ways to get a screenshot,The best way imo is to use SeleQ (for best quality) or Fexplorer (for not so good quality) and save it as .bmp.
If you are posting the theme at symbian themes you will need a .jpeg screen shot to upload,which you can take on the phone or convert on pc.
Ok I have tried saving a screen shot with seleg and it says hold (ABC) + Joypad Center and nout happens wat am i doing wrong and is it actully working???
k wrote:Pencil + Joypad center
and seleq must still be running in the background: start seleq and then press the red button to switch it to the background..
tias wrote:and seleq must still be running in the background: start seleq and then press the red button to switch it to the background..
Ok cheers Guys All Sorted.
Does Windows 97 exist?
windows 97 is the one with internet explorer and multimedia thingy. just a nick name though
