Voice dialing with bluetooth
3 replies · 2,541 views · Started 05 May 2004
Hi guys, hope you can help me here. I've tried searching through the forum but have had no luck finding an answer to my problem.
I've just bought a bluetooth headset (a Bluetrek G2) to use with my P800, and I remember reading ages ago that you get the best voice-dialing performance if you record the tags using the headset microphone. However, I can't figure out how to do this - when I try to record a tag, it automatically uses the phone microphone.
Can anybody help me?
Chris
I've never heard of that particular headset so can't help you with that. However, I've never had any problems with voice recognition though my headset (Jabra BT200) and I record my tags directly on the handset.
don't think there's an option to record through the headset... so the normal way through the phone should work
and if it's clear enough, your headset will recognise your voice and dial through it!
