Ok, need alittle help folks.
1 replies · 1,550 views · Started 05 May 2004
When I installed a Java game it brought up the message ChildInstaller and closed it down, it also gives this error when I try to uninstall them. However, I think I know how to fix this by formatting the MMC and soft formatting the phone.
I took my memory card out and proceeded to play around with the phone, Snake and MixPix worked where they didnt before with the MMC in, when I put the card back in without formatting it, Snake and MixPix work but when I try to run the other games ive installed it comes up with 'AppArcServerThread'. I still cant remove the games as it comes up with 'ChildInstaller'.
So I was thinking that I could use my MMC reader/writer to remove the offending applications but the trouble is I dont know which ones are the ones I installed and which ones came with the phone.
What do you think I should do?
Its ok folks, ive just formatted the memory card and everything seems to be working again, i didnt need to format the phone at all.
