Low volum of wav tones
11 replies · 3,400 views · Started 05 May 2004
i have many wav tone
but when i transfer it to my phone the some are very loud but some are very slow
how can i make the loud(the slow ones)my phone volum is on full
The slow ones are quiet because of the tone of the wav,the speaker hasnt got the frequency. 😡
You can also use a WAV editor like Audacity (find it on htt://www.sourceforge.net/) to change their loundess and any other aspect before you transfer them to the phone.
N/A wrote:You can also use a WAV editor like Audacity (find it on htt://www.sourceforge.net/) to change their loundess and any other aspect before you transfer them to the phone.
please tell me clearly from where should i find wav editor
i reeally want that and want to make load my wav files..
i'm using nokia 6600.
but i don't have any kit to connect to computer,
to download or transfer file.
so can i noe where can i downloads wav tones
or mp3 through WAP?
Audacity handles WAV (waveform audio) files, not MIDI files.
There are MIDI editors out there, too. Try googling for them.
Install it. Run it. Open a WAV file. Select a section or all. Select "Amplify" from the "Effect" menu. Repeat as necessary. Save.
For further details, select the "Online Help..." option from the "Help" menu and read on.
